I'm looking to build a 2 ch. home audio system. I guess what I'm now interested in is a pretty fat stereo setup. I listen mostly to classic rock, however, this setup will be for a fraternity dorm so rap is a must when partying. What I'm looking for is something that can get loud and sound great at the same time. I'm really not very sure what I'm looking at power wise. My budget is $800 for the speakers and crossovers. The sub (already taken care of) and receiver is not included in the budget. Any suggestions?
Home Theater Stereo Setup Help
$800's just shy of the big WWMTM RS 3-way towers (see M-A) which I think would fit the bill nicely (though they do take a robust amplifier). Though I'm not sure if your budget includes boxes or not.
However, I'm not really sure that the ultimate low distortion and crystal clear quality of this type of project is as suited to the type of abuse they'll likely get.
Something along the lines of the project published over at Parts Express recently may do well, though I can't vouch for its sound quality. It should also be well below your budget.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
I've said it before, and I'll say it again- when you want to build something for college parties, use pro sound drivers.
They have a lot of sensitivity, so you can get loud without a huge amplifier. An added bonus is that they get loud enough before driving the amp past its doom (and a distressed amp tends to take the speakers out with it). Pro drivers are also built to take a lot of abuse- such as being overdriven.
The project CJD mentioned looks good, but you could probably do better. Here's the link: http://www.partsexpress.com/projects...gna/index.html
The sensitivity is supposed to be around 90 db, with extension below 40 hz.
What subwoofer are you using?-Joe Carrow- Bottom
I agree - pro drivers will help on the party end.
They may not pass the critical listening end, but for classic rock it's also very likely they'll do just fine.
90dB isn't much... the RS 3-ways are in that range (at any rate, the tweeter is not padded, and that's rated 90.5)
I'm sure the PE design will have plenty of BOOM, if that's the goal.
I'm sorry I don't think I was as specific as I should have been. I'm not looking for a PA. This will be for my room. I have a sub already that I plan to build a sonotube enclosure for. As far as the speakers go, I want some fatty floorstands that will sound as best as my budget will take me while they have some balls to keep up with the RE SX15.Last edited by BigPuss; 04 August 2006, 03:58 Friday.- Bottom
The sub won't be much to keep up with.
If you're after absolute Sound Qualtiy, one of the RS 3-way projects in the Missions Accomplished area will do you well - the WWMTM's (bigger but also more expensive) or the TMWW's. Build either sealed (well, the WWMTM's are only sealed - no ported option), and cross to your sub at ~60Hz give or take.
I actually had put some thought about using this design
Except I wanted to use double the drivers in each cabinet and just skip the subwoofer. The guys at CarStereos.org shot that one down though...- Bottom
Well, the design isn't the problem, it's your casual approach to making pretty significant changes to it.
It's not a particularly excellent design, but it's also not a bad one given its goals - fair budget, decent sensitivity (I wouldn't call it high by any means - but much higher than many projects, yup), it'll thump and generally supply tunes for average partying.
I'm curious, what reasons were given for shooting that design down?
Eh... That's a box design choice. Some low frequency extension is given up, but you get better power handling and a smaller enclosure. You could use a bigger box and come up with a slope that's more to that poster's liking.
In my opnion, that's a fine frequency response for your application. Below 50 hz (depending on your room size), you'll get some low frequency boost from the room. If you can hit 30 hz solidly, you're in great shape for a 60 hz crossover to the "real" sub like the one you're planning. The PE speakers would probably hang in there with two subs of the size you're talking about- they'll be great for you if you use just one.-Joe Carrow- Bottom
Do you want to design your own speaker, or use one that's designed?
WHen you change design parameters (change the number of drivers) you're on your own, for the most part.
Doubling the number of drivers would at most give you more power handling. You would also, of course, have to double box volume.
And, most subs for car application have even worse curves. Port and you get a steeper roll-off. Tuning frequency, box size, all play a role of course.
If you read all the data about the design, I believe the designer explains why he chose that range. I should think that the "car audio guys" should understand that SPL rolls off drastically below the tuning frequency which was 34HZ. It didn't look to peak too much. Output in a range where most music stays above. For the occasional sub 30HZ drop, your sub would have that covered. You may be able to build those and add something else. New budget reciever, nice sub amp, FBD or maybe a keg?
My .02- Bottom
You know I completely forgot that my dad has a crazy set lying around. I recently had come accross this old home 3 way set that he had from the mid 70's. If you are familiar with horns I'm sure you might have heard of the old Altec Lansing based company called University. Anyways. This set includes 2 tweeter drivers, 2 midrange drivers, and 2 low low excursion woofers, all complete with crossovers. Would this be a better option than the PE setup? I'm just wondering if the horns will sound harsh and tin cany. Does anyone have any knowledge of this kind of setup?- Bottom
you can get a cheap sony or insignia 2 channel reciever to abuse
i've posted pics of the insignia internals... well built
you may be best off getting some jbl pro speakers or similar http://www.guitarcenter.com/shop/liv...+324599&page=1- Bottom
Ok, well I ended up picking up 2 Memphis 15-MC124D's to pair up with the 500 watt BASH plate amp. What size enclosure and what tuning/port area do you guys suggest I use? I was thinking about tuning around 25hz. What do you guys think?Last edited by BigPuss; 09 August 2006, 11:04 Wednesday.- Bottom
