Welp I'm on a limited budget, have $600 total to split between tools and my first Subwoofer build (other thread). So I'm coming up with a list of the barebones essentials I'll need so I don't cut too far into the sub budget. Just FYI I'm lucky enough to be less than 20 minutes from a Harbor Freight retail location and have 3 or 4 Home Depots within a 10 minute drive.
Here's the list:
HAVE:
*** Jig saw, circle saw, mitre(spelling?) box, belt sander, tons of sandpaper, files, drills, dremel tool soldering iron... and a truckload of sweet automotive tools that are of no use for working with wood
- GF says in laws may have a router... but that may be more hassle than its worth.
NEED:
*** Sawhorses and a strong piece of wood for a work stand should be ok I think.
I saw some decent sawhorses for cheap at Home Depot that would do the trick
*** Clamps. I'll need a bunch of these I'm sure. should 8-10 do
Probably get from harbor freight and if the break I'll return / exchange em.
These two are a little more expensive but seem to have more contact area.
Cheaper ones
*** Jig blades
*** lung protection. this I absolutely wont skimp on
or http://www.harborfreight.com/cpi/cta...emnumber=44113
anyone have an opinion if the straps are worth it?
NICE TO HAVE:
*** Router
Is this one junk? I know its underpowered but at $40 I don't have that much to lose. But if it would be essentially the same as trying to use my dremel then I'll forget it.
Here's the list:
HAVE:
NEED:
Cheaper ones
*** Jig blades
NICE TO HAVE:
*** Router
