ok so this is an idea i had in my head for a pretty long time. I studied the problems and compromises i should make in order to achieve that, and i think it's not impossible
i want to take one of theses as a woofer, possibly one of the scanspeak revelator, as i assume they are the lowest compression/distortion 10" alu drivers one could find
Scanspeak 25W8567-SE
Revelator 26W/4867T00
Seas excel W26FX
Seas aluminium 10"
and couple it with a very good tweeter, possibly the accuton c-23, or the seas excel.
as you guessed, the aim is a tweeter that can go low without strain. If you have other alternative i'm open to it.
i would put that tweeter in a oblate spherical waveguide ( according to Dr.Geddes theory) of 10" or 12" diameter, with 90° angle coverage, in order to have a good gain down to 800-900 hz. I could possibly do the waveguide even larger ( 15") if necessary.
i'm not worried about the inherent size of the woofer for a two way, as the aim is sort of constant directivity, beaming of the woofer is wanted.
as i would cross over at 800-1000hz ,(with a computer and some FIR filter i conceived, with very steep slopes) i'm much more worried about inherent limitations of the drivers
what do you think ? am i totally crazy, or is there something worth the effort in my project ?
thanks !
Seas excel W26FX
Seas aluminium 10"
thanks !
