Appreciate your opinion on Carvin pro-amps like the DCM2000 ($499) and DCM2500 ($569).
Helping a friend build his 5.1 HT system where the wife wants small cabinets and he wants output ... the typical case. Noisy fan would also be a negative.
Looking at the new TC Sounds TC3000 15" for a small (2.0 or 2.5 cubic foot) sealed subwoofer. Originally, I was thinking the PE 1000 watt plate amp, keeping it simple since they're not likely to ever make any changes. However, my impulse tells me to go for a proamp such as the Behringer EP2500 ($299, plenty of power, concerned about quality, reliabilty and noise). I have read some of the modifications to lower the noise but is it still discernable from 4-8 feet away while watching a DVD? I read Steve's comments that the Carvin's are discernable from about an inch away, a foot away would be plenty.
Also relying on the new HT receiver to handle the crossover cutoff, expecting to choose one of the mid-upper range Sony ES and Marantz series. The monitors will be small sealed 2-way (they have to be small, less than 14" and handle dynamic ranges without compression).
Summary:
Is Carvin worth the extra price over the Behringer?
How quiet is the Behringer, distance away can you hear it?
Should I reconsider PE plate amp?
thanks,
Al
Summary:
thanks,
Al
