Thinking MT's using the Dayton DA 175 drivers I have sitting around...
  • Exocer
    • 262
    Just completed my Natalie P's and am already dying to get my next project in gear. I have the DA 175's in hand already (thanks to Pmazz) and leaning towards a different tweeter this time around. The seas tweeter used in the Modula MT design is on the top of the list. I haven't found many designs using the DA 175 driver however so this is a bit discouraging. It doesn't have much Xmax but crossed over at 80hz I'd get more than enough output IMO. I have absolutely NO knowledge of how to even design a crossover or simulate them...Thanks in advance.
  • Jed
    • 3621
    Most people use 2 DA175s per side because of the low efficiency.
    Jed
    • Exocer
      • 262
      That makes sense...Ah well I just built the Natalie P's. No use for another MTM around here. Sorta just want to build something so the drivers are put to use...
      • WillyD
        • 675
        I'd imagine that someone here could at least throw together a xover for you. It wouldn't be perfect, but better than nothing.
        • Exocer
          • 262
          Yeah, will that'd be awesome...Nothing extravagant just a lil something something Gotta keep my DIY juices in flowing this summer...all this DIY stops come september.
          • Rudy Jakubin
            • 58
            ShawnA already built a pair;
            I'm getting really close to having 4 DA175's per side with a tweeter done pretty soon.
            • Exocer
              • 262
              awesome. :T
              • Jed
                • 3621
                Does that design have BSC? Doesn't look like the baffle was simulated into the response either.
                • Rudy Jakubin
                  • 58
                  ShawnA measured it with a test setup and it measured pretty flat.
                  He did have a slight diffraction dip that wouldn't be audible.
                  • Jed
                    • 3621
                    http://www.pesupport.com/cgi-bin/config.pl?read=288184
                    I'm still amazed how accurate these simulation tools can be. I guess that response flattened out when he tilted the speaker back a bit, too.
                    I'm going to have my measuring setup up and running this weekend.... can't wait.
                    Jed
