I'm in the process of designing two speakers. One is a dipole with dual RS315HFs in an H-Frame, along with a single RS225 up top, similar to the Orion. The other speaker is an MTM with dual RS150s. I'm stuck on which tweeter to use and have narrowed my choices down to, but not limited to, the Seas TDFC and the Dayton RS28. I like the Seas because it's a known performer and is relatively inexpensive for what you get, but I could spring for the more expensive RS28, if you guys feel it's worth it?
Basically I'm looking for pros/cons for each tweeter and which one you would use if you were in my shoes?
Thanks. :T
Thanks. :T
