I want to build some speakers for my work place. They're probably going to get dirty and its a noisy environment, so inexpensive and simple would be suitable. All the drivers I can think of off hand have some kind of breakup that require more complex xo's to deal with.
The music is mostly rock, and Id like to have some bass and power. Definately 2way, probably 6-8 inch.
Can you guys suggest drivers or a documented project?
Thanks.
Thanks.
