i've just recently installed a rolls mp13 pre-amp with a behringer ecm8000...need some pointers on the gain setting for the rolls...the gain has a range of 6-50 dB...using trueRTA and RoomEQwizard...thanks
rolls mp13 and ecm8000 gain setting
...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
2x15" TC Sounds .45Q sealed
M. Boutte HT
3x15" @ 10 HzTags: None- Bottom
If you're using Room EQ Wizard set the Rolls gain so you get a SPL match with you RS meter
Originally posted by ThomasWIf you're using Room EQ Wizard set the Rolls gain so you get a SPL match with you RS meter
ahhhh! yes...that's the way i set it up...took a measurement at about 70 Hz...i guess the RS meter should'nt be off by much this high...thanks Thomas for the confirmation...peace :T...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
M. Boutte HT
3x15" @ 10 Hz- Bottom
