Here's the somewhat "final" idea for my sub project. Two RL-p15 D4's in a enclosure that's 48x38x17 external. Final internal volume has yet to be calculated, but should be somewhere between 13-13.5 ft3. It's going to be tuned around 15-16Hz via a single 8" sonotube port. Powering this beast will be an EP2500 when I get it, until then it will be my old receiver.
Anyone see anything obviously wrong with this design?
I've got a few questions on the enclosure it's self.
1) I know that MDF and BB Plywood are the "ideal" materials, but how bad would it be if I just used regular 3/4" particle board and heavily braced it?
2) Is there any reason to flush mount the drivers, other than cosmetic reasons?
3) For bracing, I was going to use 3 horizontal pieces and some staggered verticle ones, will this be sufficient?
4) On the braces, as far as cutting holes in them, is there a preferred method? Circles? Rectangles? Triangles? This will be done with a jigsaw.
5) As far as stuffing the enclosure, would lining the walls/port with fiberglass batting be sufficient?
I'll be posting pics as soon as I put down the saw.
