Current setup: computer sound card optical -> stereo DAC XLR -> QSC RMX 850 -> Natalie Ps
I'm adding a Behringer EP2500 and 2 DIY sealed subs.
I'm trying to figure out how best to integrate the subs with my system. Sound Quality is the most important factor by a long shot and my budget is $300. So far I am considering the following options and would really appreciate some guidance:
1. 50hz filter on the QSC amp with the Natalies and an EQ unit like the Behringer DEQ 2496 with the subs to roll off the highs and adjust the lows to correct room response. ($200)
2. Behringer CX2310 SUPER-X PRO CROSSOVER 2-WAY/3-WAY (248-664) to split the signal between the subs and Natalies ($100)
3. Replace DAC with Panasonic XR57 receiver for crossover function. Additional benefits of volume control and compatibility with future additions of surrounds & center. ($300)
4. 1 & 2 ($300)
Thank you in advance for your help!
4. 1 & 2 ($300)
