I had originally planned to build a dipole much like the Arvo but with dual RS315s, duals RS180 mids and a single RS28a tweeter. The more I thought about it the less I wanted a 14" wide speaker and something that's already been built. I did some calculating and am almost sold on this design:
I'd like to run four RS225s at the bottom in a 10" wide x 8" deep dipole config, with a slight angle on the back, much like the Arvo. The angle would only be 2" in at most, and the 8" depth is not set it stone. After calculating the dipole output using Linkwitz's spl_max spreadsheet (http://www.linkwitzlab.com/spl_max1.xls) with 200 Sd, 28mm peak excursion (four RS225s with 7mm xmax) and an effective path difference of 660mm I get the following results of max output at 1 meter:
25hz=82dB, 35hz=91dB, 50hz=100dB, 71hz=109dB, 100hz=118dB
This is for one speaker, so theoretically two speakers should yield 6dB higher. My listening position is 3m away, so that should yield 86dB at 35hz and 95dB at 50hz, plenty loud for music listening. I have an infinite baffle sub in this room that can handle the lows, so I'm thinking of crossing over to that around 40hz to alleviate the dipoles.
For the top section I'm stuck with what to do. I like the four RS225s because I can create a slimmer and less expensive speaker, but at the same time I should be able to cross over to the mids higher, due to using a less deep "enclosure" and the better high-frequency response of the RS225s. With that, I'd like to use something that's better suited for mids and that can cross over higher to a tweeter, so I can alleviate the tweeter from having to produce too much low-end. I was thinking of going with a single mid like an RS150, dual mids in an MTM like dual RS125s, or anything else you guys can recommend. For the tweeter I was looking to use the Vifa XT25, due to it's stellar frequency response and distortion figures above 2khz.
Alas, I will be attending the Parts Express Tent Sale on July 15th and they will more than likely have a 20% off coupon. I'd like to stick with drivers I can get there but am 100% open to any other suggestions. Spending a few hundred extra won't kill me, and I was even considering going with a Seas Excel magnesium mid and one of the Seas tweeters. Again, I'm open to suggestions.
Lastly, and sorry for sounding stupid, but what are the drawbacks of going with an MTM over an MT? I would think there would be some serious cancellations due to the increased center-to-center spacing but seeing so many MTMs I guess it's not that bad? I do know they have worse dispersion? than an MT does so if you guys think I can get away with going with a single mid for a killer dipole speaker (in this config with four RS225s) then please, let me know!
Sorry for making this so long but I wanted to throw it all out there. I'm open to ANY suggestions/criticisms you may have and would really appreciate them.
Thanks! :T
Thanks! :T
