Looking for a small surround speaker project, very small
  • hoggy
    • 18
    I just moved into an apartment and need some surround speakers. They need to be light so I can easily hang them on the wall that is directly behing me. Are they any projects like this somebody might be able to show me. Something relatively cheap if possible.
  • hoggy
    • 18
    Probably something with no bigger than 4" driver.
      Not many of those around.
      Checkout the projects on JKrutke's website. He has several small boxes.
      • hoggy
        • 18
        Is there a recommend configuration for surrounds when there is a wall directly behind you? I had seen Zaph slimline before and though it was cool but not sure if it'd work for rears on the back wall.
          Since they're designed to be wall mounted they'll work. Those little woofers won't move much air though...
          • jonathanb3478
            • 440
            http://www.zaphaudio.com/
            I had not seen that site before. Excellent stuff, over there.
            I like the waveguide TMM he has.
            -Vernon Sanders Law
