Need help with box specs for a certain subwoofer
  • slayer
    • 216
    I was hoping someone could run the theil small parameters of my sub through their program to tell me what the proper volume enclosure would be for it. I will email the specs of the sub when I get a response. It is a 15" Diamond Audio TDX subwoofer. Dual 2 ohm model. I will be running it in series for a 4 ohm load. I sell Velodyne subwoofers and used my connection to get one of their 1000w SPL-R plate amps. I also have one of the SMS-1's to help dial it in when finished. Any help would be great. Thanks.
    Parasound Halo C2
    Earthquake Cinenova Grande (5ch amp)
    Crown X1000 (2ch amp)
    Oppo BDP103
    Musical Fidelity Tri-Vista 21 Tube DAC
    Xbox One
    Monster Cable Signiture Series HTPS 7000
    Panasonic 60" ST Series Plasma
    BenQ HT1075 projector w/ 92" Dragonfly screen
    Energy Veritas 2.2i fronts
    Energy Veritas 2.0i center
    CAT Tiburon series side surround
    Energy E-XL 15 rear surround
    Velodyne SMS-1
    Custom 15" sealed sub (Diamond Audio TDX15)
    • slayer
      • 216
      That didn't seem to work for me. Anyone have a high tech program they use?
      Parasound Halo C2
      Oppo BDP103
      Xbox One
      Velodyne SMS-1
      • slayer
        • 216
        Here is a link to the specs of the sub. It is the TDX 15/ D2 model on the chart. I want a sealed enclosure. Thanks.
        Parasound Halo C2
        Oppo BDP103
        Xbox One
        Velodyne SMS-1
        • Jack Gilvey
          • Aug 2001
          • 510
          Not sure if it's higher-tech than Dennis' (which worked fine for me), but you can try this:
          ~79L sealed given the lowest, flattest response.
            Yep and they're free for anyone to use. WinISP Pro or Unibox
            • slayer
              • 216
              Did you run the specs to get 79L? What is that in cubic feet? What did the respose look like?
              Parasound Halo C2
              Oppo BDP103
              Xbox One
              Velodyne SMS-1
              • Jack Gilvey
                • Aug 2001
                • 510
                I ran them using that WinISD online calc and it gave me 79l for a maximally flat, 0.7 FR.
                Running them in Unibox gives me a different Qts than that .pdf lists, though, and the box I get for the lowest F3 in Unibox is only ~1.5 ft^3. F3/Fc is about 40Hz in that size with some stuffing, but it's really inefficient. Here's what it looks like with 1000 watts:
                • jonathanb3478
                  • 440
                  'bout 2.79 cu ft
                  -Vernon Sanders Law
                    A cool new Google feature is their built-in units converter. Use the keyword "in". "79 liters in cubic feet". I haven't found any units it doesn't know so far. It even translated furlongs per fortnight into miles per hour.
                      This is great news, you don't know how many sleepless nights I've spent trying to figure that exact conversion....... :B
                      • Amphiprion
                        • 886
                        What about rods to the hogshead?
                          Sorry, it couldn't do that one. However, it told me that 1 cubic rod = 533.387753 hogshead. :B
                          • Amphiprion
                            • 886
                            We need to get them to add that one, it was referenced by "Grampa" in one episode of the Simpsons as his preferred measure of fuel economy
                            • slayer
                              • 216
                              It's hard to tell from that graph where it's starting to drop.
                              Looks like it rolls off in the lower end too quickly. Is this a problem with this sub or the fact it's a sealed enclosure?
                              Or does that look like a good response. I want a good all around sub for music and theater. So I will need it to play low for the theater use.
                              This sub was designed for car audio so I wonder if it is just not fit for this kind of use. Should I go with something else? I already built the box and am just finishing it up. I went with a 2.9 cubic foot enclosure. I had been talking with the tech department from Diamond Audio and he reccommended 2.75-3 cubic feet. I was just posting here to see if was correct. Does the response look like it will be good?
                              Parasound Halo C2
                              Oppo BDP103
                              Xbox One
                              Velodyne SMS-1
                              • Scott Simonian
                                • 216
                                "In Soviet Russia, car drives YOU!"
                                My Sound Splinter 18's each in 25cuft boxes w/ EP2500
                                  Ah, sorry Mark, I misunderstood. Google lets us know that:
                                  1 rod per hogshead = 4.96031746 × 10-5 miles per gallon.
                                  Fun with science.
                                  • mmoeller
                                    • 138
                                    Does this type of speaker with a fairly high Bl and Xmax take alot of power to drive in a sealed enclosure by design? I have been following the threads for the TC Sounds TC-3000 and 2000 and they seem very similar. Although the TC speakers seem to simulate a bit more SPL for a given power, they have the same type of low end roll off as the Diamond 15. Vented versions will stay flat longer, but will roll off even faster. Am I correct in my assumptions?
                                    • Jack Gilvey
                                      • Aug 2001
                                      • 510
                                      Going to 3ft^3 does increase the deep bass efficiency somewhat, and gives a less steep rolloff. Looks pretty good in that box with 1000 watts, although still pretty insensitive on the whole. It's basically a car driver, designed for small boxes and lots of power. Looks decent, though, if you get it and the amp for a good price.
                                      • slayer
                                        • 216
                                        Thanks for the help. I already have both and the box done. I am just wrapping up the finish on it. I used 1.5" & 1" MDF for the building material. All walls are 2 layers of the 1.5" and the baffle has an axtra layer of the 1". I used the 1" for bracing. Then coated the entire inside walls with a flexable caulk for deadening. I loosly filled it with poly fiberfill before mounting the driver. The amp sits on it's own. I figure a crown or something down the road would be a better choice. Not sure if the Velodyne puts out what it claims. 1000w rms / 2000w peak
                                        I will try to get some pics of the finished sub up soon. Not sure how to though.
                                        Parasound Halo C2
                                        Oppo BDP103
                                        Xbox One
                                        Velodyne SMS-1
                                        • Jack Gilvey
                                          • Aug 2001
                                          • 510
                                          Sounds like it'll be a great sub, enjoy. The only remaining question is any EQ present in the Velodyne amp, which can radically change the response . What sub is it intended for?
                                          • slayer
                                            • 216
                                            I have the Velodyne SMS-1 to handle all the EQ, X-Over, Phase..........
                                            Parasound Halo C2
                                            Oppo BDP103
                                            Xbox One
                                            Velodyne SMS-1
                                            • Jack Gilvey
                                              • Aug 2001
                                              • 510
                                              Great piece. The reason I asked about the amp is that they amps intended for specific commercial subs almost always have a built-in infrasonic/rumble filter designed to protect the driver. The can roll off the bottom end quite a bit. Any idea which sub yours is used in?
                                              • slayer
                                                • 216
                                                Yes, it is the same amp used in the SPL-1200 sub. So it would be the 12" SPL sub they use.
                                                Parasound Halo C2
                                                Oppo BDP103
                                                Xbox One
                                                Velodyne SMS-1
                                                • Jack Gilvey
                                                  • Aug 2001
                                                  • 510
                                                  I guess your best bet is to build it and give it a whirl...I don't know what kind of circuitry might be built into that one.
                                                  • slayer
                                                    • 216
                                                    I'm not aware of any subsonic filter in that amp. If there is one, I would guess it would be below where this sub design already begins to roll off anyways.
                                                    If I can't get the low output I want from it, I will just build another sub just for that and add it to the room. The Earthquake Supernova MKV is a sub that plays very low so I could just build one like that. Or try a tube type I keep seeing on here.
                                                    Parasound Halo C2
                                                    Oppo BDP103
                                                    Xbox One
                                                    Velodyne SMS-1
                                                      It's not unusual for there to be custom circuitry in mfgr's plate amps at are EQ'ed for their drivers...
                                                      • slayer
                                                        • 216
                                                        It's a temp anyway. I plan on getting a good amp down the road. The sub is a dual 2ohm VC so a good 2 channel amp should push it well. This will also get me the most out of whatever amp I decide to use. We will see how it works.
                                                        Parasound Halo C2
                                                        Oppo BDP103
                                                        Xbox One
                                                        Velodyne SMS-1
                                                        • slayer
                                                          • 216
                                                          I keep reading where Serenity & War of the Worlds has serious Bass below 20Hz. Anyone know if this is the case? I have played both and they both dominated my room with vibration. The sub handled it fine. It was seriously moving during the opening of Serenity though. It did not bottom out though. I have played a couple Bass CD's designed for car audio systems to test it out. One of the tracks plays sweeps from 30hz to 10hz and warns to turn down the volume. At the low point, the sub is moving with no noise yet my windows of the house shake violently. Very cool to feel the bass when you can't hear it. Anyone know what frequencies these movies contain so I know what my sub is playing?
                                                          Parasound Halo C2
                                                          Oppo BDP103
                                                          Xbox One
                                                          Velodyne SMS-1
                                                          • Jack Gilvey
                                                            • Aug 2001
                                                            • 510
                                                            I doubt bottoming would be something you'd have to worry about with that driver/box combo given how much power it takes to get it anywhere near Xmax, especially if there's filtering present (likely the case). Getting through a passage without bottoming doesn't tell you what the sub is actually doing, though...can't the SMS-1 show your FR, how deep the sub is going? Here's a page with individual tones you can burn:
                                                            This thread has waterfall plots of lots of movies that show their LF content:
                                                            We discuss and review all genre of movies, all types of home theater hardware, and maintain one of the longest running active forums on the web!
