Scan-Speak D3004-6600 "Aircir"
For you guys that have Praxis. Is it possible to change the frequency scaling to linear vice log?
I don't find the distortion plots from npdang particularily helpful. He plots everything with a 20-20khz log scale which "packs" everything way to the right. It makes it very tough to see the higher order harmonics. In addition to that the non-linear distortion plots for many of the drivers he tests are flawed and show little to no resolution of the peaks above the baseline level. There's something wrong with his test setup, but not being familiar with Praxis I don't know what it is.
Cheers,
Davey.- Bottom
