f6 bandwidth defined?
  • kramskoi
    • 59
    how do we define f6 bandwidth in sealed and vented subwoofers?
    ...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
    2x15" TC Sounds .45Q sealed
    M. Boutte HT
    3x15" @ 10 Hz
  • Marzen
    • 302
    I'm not sure if this is what you're asking, but in general I think you can factor in the following:
    A vented enclosure acts as a 4th order HP accoustic filter (24dB), add a rumble filter for an additional 2nd order HP (12dB) & you have a 36dB slope which is rather substantial when compared to the more gradual 2nd order HP properties of a sealed box. Comparing the two would show the vented box having a much narrower bandwidth due the faster rate of roll off.
    -Ward
    What if the Hokey Pokey really IS what it's all about?
    • kramskoi
      • 59
      -Ward
      Thanks for the reply...i should clarify. I'm wondering whether it (F6 or -6dB point) is measured from Fb or the highest peak in the frequency response.
      M. Boutte HT
      3x15" @ 10 Hz
      • Amphiprion
        • 886
        I always thought it was defined relative to the nominal passband sensitivity.
        • Marzen
          • 302
          Ditto, I've been using an averaged passband level for reference.
          Why, are you looking at a design with a large hump at the knee like with a super boom box alignment with a Q >1.2?
          -Ward
