Sealed Box Designs with RSS315HF-4
  • ramonbet
    • 4
    I'm new to this community and was looking for recommendation for a passive sub design using the Dayton RSS315HF-4 in a sealed box. Are there any succesful designs out there? I already have two of these speakers looking to build two cabinets.
    I'm looking for a great transient response and will be counting on the room to help extend the low end.
    Thank you
  • Mark Seaton
    • Aug 2001
    • 197
    What are the dimensions of your room? What sort of construction? Basement/concrete, main floor gyp/stud, lots of windows or none?
    With just a little help from an outboard EQ, even the cheap BFD, that driver looks pretty well suited to what you are after.
    Mark Seaton
    • Marzen
      • 302
      I have two flavors, a box Q of around .7 for maximally flat; and a .5 version for the critically damped. I built the second one. Both are single driver, sealed enclosures. If you're interested I can post either later this week after I get my pc back together.
      -Ward
      What if the Hokey Pokey really IS what it's all about?
      • ramonbet
        • 4
        Originally posted by Mark Seaton
        What are the dimensions of your room? What sort of construction? Basement/concrete, main floor gyp/stud, lots of windows or none?.
        Mark, my room is the typical wood studs/sheetrock walls with a carpeted floor. It's on the lower level of the house with two 34" windows. The size is about 12'W x 20'L x 8'H.
        My friend will build the same design, but his room will be slightly larger and the entire house is concrete.
        [QUOTE=With just a little help from an outboard EQ, even the cheap BFD, that driver looks pretty well suited to what you are after?.[/QUOTE]
        My friend and I will both use the Behringer DCX2496 electronic crossover. In my case, I will also add a DEQ2496 EQ/RTA to level out the frequency response. Both of us will use the sub enclosures as stands for our satellite speakers.
        Thank you
        • ramonbet
          • 4
          -Ward
          Hello Marzen,
          I'm interested in these designs, so please post them when you have a chance. Could you comment on how the one you built sounds?
          Thank you
          • MerlinWerks
            Second project down on this page...
            • Marzen
              • 302
              Originally posted by ramonbet
              Hello Marzen,
              Thank you
              Hi - you have a PM for the files.
              Ward
              • Jack Gilvey
                • Aug 2001
                • 510
                Hey Ward...Strat?
                • Marzen
                  • 302
                  Originally posted by Jack Gilvey
                  Hey Ward...Strat?
                  Yes, my 'Vonnie' - American Std, mid 90's.
                  • Jack Gilvey
                    • Aug 2001
                    • 510
                    Ahh..I had me a mid/late-90's Am Standard, also. Lately I've gone Mexican with a Deluxe Players...best guitar I've owned.
                    • ramonbet
                      • 4
                      Thanks for the reference, MerlinWerks. I downloaded the info.
                      Ramon
