Hi all, I think I've started to catch on to what is available here enough to get started. Quite an opportunity, thanks Jon and others who work out the designs. I wanted to check in with my plan and a couple questions. Would like to know about any experiences with similar systems.
After much pondering I am leaning toward building MT's and sub instead of Natalie P's (even tho I agree Leon was her best role, Jean Reno was great too). Reasons are I'd like to not go too tall, and I want low bass.
My room is narrow but has some saving grace by being long - 11.5' x 26.5'. System is set up on one 11.5' wall, but speakers are out 5-6' which is nice, but only 2.5' from side wall to speaker center line, drat. Main listening seat is 17.5' from front wall (11'+ from speakers, good soundstage for a small room). I typically toe in speakers more than usual to avoid some side wall reflection.
I have a pair of Meniscus 1284 subwoofers in 3cf sealed cabs. I'd like to eventually try the RS315HF's and can use these cabs. Have Marchand XM-1 electronic xo kits to be built. Is their 24db slope possibly compatible with MT's? I'm open to getting a plate amp that someone would recommend too. Have an Adcom 555 that needs a little work, would that be good enough with 315's and xm-1's? (The Adcom/1284/xm-1 bass system isn't up and running as it needs work. So it's a good time to replace anything.)
I'm hoping for good power handling as I play it loud at times. Will use as a music system mostly, but movies sometimes too.
I'm a woodworker with a shop so construction will be no problem. I've built several speakers using North Creek method, and have their 14ga coils, Zen caps and Ohmite resistors to use on xo.
Thanks, Don
Thanks, Don
