Hi, I absolutly do not know what I am doing, as you will see in my post. I think I would like to build a design using the Phoenix concepts...seperate di-pole woofers and a seperate di-pole main panel. I hope drive them with two seperate SS amps 350/channel on the woofers 200/channel on the main panels. I would probably try to control the distribution to the two amps using a external Berhinger or DBX drive rack type unit. I know all of the wonderful work that has been done to create active crossovers with this design, but I do not think that is in my skill set at this time. Can I / is it possible to create a passive di-pole main panel using off the shelf crossovers designed for a MTM system. i.e. can I get the "Odin" parts & crossovers from Madisound and use this for my di-pole panels....AND can I substitue the Seas W22 for the W18 and still use the same X-O ????
Like I said, I know nothing, just want to build on others work who know more than me......
