I am building a ported Sound Splinter RL-p15 sub in a 260L enclosure. I found a really good deal on a pro amp made by Numark. They are a pretty big name in DJ gear like turntables and stuff but I don't know about their amps. I was able to dig up a couple of user reviews (all in Europe interestingly) and they were all very good. However the specs have me wondering. First of all there aren't many specs offered (which I consider a potential bad sign) but some of the features on this amp are pretty nice. It is the Numark Dimension 3 and here is a link to the website http://www.numark.com/pdf/manuals/Dimension 3.pdf . Let me know what you think or if you have any experience with these.
One of the things I like about this one is the signal pass--thru feature. This would work nice for my bass shakers so I wouldn't have to split the signal. It also has muted power up feature which is kinda nice. Really the only thing that has me worried is the THD which is said to be only .002% in the features list but then later says it is 1% at 20Hz to 20kHz at full power. Makes me think that maybe the .002@ is at like 1Watt power or something and 1% is at full power. Another interesting note is that the THD on the EP1500 is also 1% in 4Ohm bridged mode. Is 1% THD enough to make an audible difference?
Also-
I noticed in the specs for the Behringer EP1500 that the output is -10db below 20Hz. Now this may just be "how it is" for all amps and it is just conveniently left out in the specs for the Numark but a 10db loss is quite a bit when you are talking about the frequency range that you are paying more money and doing more work to get down into.
Also-
