Hi, this is my first post but I've been reading this forum for some time now. There's a mind-boggling amount of information here, I don't think I'll ever finish reading it all...
I had the insane idea of building a complete 5.1 set for my home theater. My goal is to get a better overall sound than my current commercial setup, and have fun in the process.
For what it's worth, my current setup is :
- Linn Ninka Front (closed box MTM 6.5" poly woofers, 3/4 soft-dome, 2250Hz xover)
- Linn Trikan Center (closed box horizontal MTM 5" poly woofers, 3/4 soft-dome, 2500Hz xover)
- Linn Kan Surrounds (MT ported 5" fiber woofer and 3/4 ceramic tweeter)
- Energy 18" paper cone closed box sub
My Tools :
- ETF 5
- Behringer 8000 mic with m-audio mobilePre on a laptop
- freeware/shareware I can find
My Skills :
- minor experience with DIY speakers. I read the loudspeaker cookbook about 10 years ago, made a ported sub, a closed box 2 ways, and a ported 2 ways. Didn't have any mesuring tools at the time.
- electronics skills and experience to design an elaborate active xover
- plenty of time to build and experiment, I give myself about 6 months to finish the project
Here's where I am right now in my criteria and decisions :
- Primary goal is to improve on Imaging, Details and Voice intelligibility compared to my current setup. I realised these qualities were lacking on my system when I went to the Montreal Home Entertaiment Show. The best speakers I heard at the show last year was a compact MTM design with what looked like a modified Mundorf AMT tweeter, and Skaaning midbass. A 5.1 kit of those was the cost of a luxury car. I hope to reach toward this sound quality with a DIY design.
- I want a Closed box design. I'm leaning toward closed box because, subjectively, I always prefered the bass of closed box. The gain of a ported design isn't necessary if I have a sub, and the sub integration should be better with a closed box. Dipole is beyond my skill level and would be difficult as a 5.1 system with only 32" height under the screen.
- Analog active crossovers. This is fun to build and play with, and also very inexpensive to modify and improve. I am more confident in my ability to design a line level xover than a passive one.
- Drivers must be available in Canada, because of the lower shipping cost and to avoid random problems with customs (had too many of those with UPS).
- maximum SPL : I usually watch movies at most around -10db of Dolby Digital level, usually lower. That is 95db peak at 12 ft, so about 107db at 1 meter.
- I want two subs to allow a vertical center channel, and to get more options for placing subs and adjust the room response.
- I want 5 identical speakers, so I can be assured of a perfect match.
- I have 32 inches of clearance under my projection screen for the center. Drivers for the center must be as close as possible to the screen, so I think an MT design is the best choice. An horizontal MTM would be better, but I understand it requires extreme mesures to acheive a good dispersion. A 2 way MT design with sub should be enough to reach 107db@1m.
Drivers :
Mundorf AMT are too expensive, so are the Skaaning drivers.
I first decided on the following drivers because of all the praises on the forums. There are plenty of DIY projects using those, so I would have a lot of references available, and I could be merely modifying an existing design :
tweeter : Millenium
midwoofer : W18E or W22
subs : Peerless 830845
system would be five identical MT on stands, with 2 subs.
However, being a little more daring, I would prefer to try the Eton ER4 with the W18E. It would be a lot more work on the crossover side and a more risky design for my level of experience, and the rear chamber will need a lot of experimentations, but I think I'm up to it.
Is it a bad idea to try pairing the ER4 with the W18E ?
I'm playing around with The Edge right now, is it reasonably accurate with rectangular tweeters ?
Anything in my criteria that do not make sense or possibly ill informed decisions ?
My Tools :
- ETF 5
My Skills :
Drivers :
tweeter : Millenium
