Hi i notice the behringer feedback destroyer 2496 used alot for sub but is the 1124 ok also, some cheap sells right now on the 1124 unit thanks
Which EQ?
the 1124 is fine. that is what I use.- Bottom
If cost is an issue then get the 1124P. If the budget is higher get the DEQ2496
The FBQ2496 is just a newer version of the 1124P.
Behringer is discontinuing the ($99) DSP1124P. It's replacement is the ($150) FBQ2496 The newer unit has improved ergonomics and more filters, 20 per channel vs 12. If you don't need the added filters and want to save $50 get your DSP1124P now, while the retailers still have stock. 01/16/07, Edit to update,
The DEQ2496 is specifically designed for EQ, not controlling feedback. It has the higher-end SHARC DACs. And more functions than a Swiss Army knife
