I posted this over at AVS Forum and was told to ask here.
Hi, my dad and I are going to build our own speakers using drivers from Parts Express. We've picked out a few drivers for each range, and we're going to see which sound best and send the rest back. We're using a near cubic box around 1.4 ft³, and we're only going to be putting the woofer in it. No tweeter/midrange, unless it's a problem (explaining later). Here're the parts:
Tweeter
Davis Acoustics TW26T soft dome
Hi-Vi TN28 soft dome encapsulated
some metal dome tweeter, hopefully
a planar/ribbon tweeter
Midrange
Dayton metal dome
Morel MDM-55 soft dome
or
Usher 9845 soft dome
Woofer
Aurum Cantus AC250F1 10"
What we're going to do is make a sealed box for the woofer only, then make another stand-like thing for the tweeter/midrange that can be moved around a bit. We've done it on previous speakers that we modified and they sound great. I'm just wondering if it's making it sound worse than it could, and if the separate stand presents a problem. Also, if you have any comments/recommendations for the drivers, please let me know. I'd like to try a metal dome tweeter and a planar/ribbon, but all I've found are titanium ones that seem cheap, and 4 ohm aluminum domes. I don't really know what to pick in the planar range, either. 8 ohm is preferred as well unless it is possible to raise the impedance easily. Thanks in advance.
Tweeter
Midrange
Dayton metal dome
or
Woofer
