Hey I am thinking about a RLP15 in a sealed appliciation with a Crown amp XLS602. I believe its roughly 1500 watts at 2Ohms. Would this amp work and how loud are they? Thanks
Anyone use Crown to power sub?
Yes it will work, you can save money by getting a Behringer EP1500 or 2500 instead.
You can model the anechoic output using your box design in Unibox
It is second hand light use minor scratches for only $200 shipped. I think its a deal? Does the fan run all the time and do you guys just leave the power on? Do you know if i can switch out the fan for a panaflow? It only has XLR is that a problem? Thanks- Bottom
Don't know much at all about those amps, we always recommend the Behringer given it's lower retail price.
Look at the online owner's manual to find out about running it single ended.
Originally posted by nick77It only has XLR is that a problem?
$200 sounds like a good deal, less than half of the street price - I bought an EP2500 new for just a little more. The fan can be slowed down by using a resistor, there is another thread around here that describes how.Danish- Bottom
Originally posted by nick77Its not as easy as buying an rca to xlr connect? Glad I am asking. Thanks
The only difference is that the "outer" contact ("sleeve" maybe) on the RCA connector will be connected to BOTH the (-) signal (pin 1) and the ground (pin 3). The center pin will be connected to pin 2 on the XLR side.
You can also buy adaptors that look like an XLR termination but have an RCA jack on one side. It is cheaper to build a cable though. Doug (CAT Cables) could probably make you a very nice one quite resonably. Otherwise, you can buy the parts and wire and make your own.Danish- Bottom
Originally posted by dyazdaniThe only difference is that the "outer" contact ("sleeve" maybe) on the RCA connector will be connected to BOTH the (-) signal (pin 1) and the ground (pin 3). The center pin will be connected to pin 2 on the XLR side.- Bottom
$200 is not fabulous for the Crown, but it's not bad - i.e. worth it as long as it's not too beat up.
Lots of people using them for main amps and sub amps.
The fans do run all the time and from what I've heard they are fairly noisy. The mods run from eliminating the fan(s), to putting in a resistor, to replacing with a quieter fan.
Since you are talking 2 ohms, I'd say to refit a quieter fan of similar CFM and to be cautious about eliminating or slowing the stock fan.There are some things which are impossible to know, but it is impossible to know which things these are. :scratchhead:
----JAFFE'S PRECEPT- Bottom
As has been mentioned, Crown XLS doesn't have variable speed fans, and fan noise has been measured as ~72db at 1" - that's very loud. In addition, response is already down ~3db at 15hz - that may be low enough for your needs, but what does that say as to how it will be performing in the 15-25hz range? Damping factor seems kinda low too to be powering a 15" sub. I don't think these amps are suited too well for subs, better to leave them for speakers.- Bottom
Originally posted by chasw98Not to nitpick, but pin 1 is shield and pin 3 is the "-" pin. I usually wire mine as center conductor "+" on the RCA to pin 2 on the XLR and shield "-" on the RCA to pin 3 on the XLR.Danish- Bottom
Originally posted by SteveCallasAs has been mentioned, Crown XLS doesn't have variable speed fans, and fan noise has been measured as ~72db at 1" - that's very loud. In addition, response is already down ~3db at 15hz - that may be low enough for your needs, but what does that say as to how it will be performing in the 15-25hz range? Damping factor seems kinda low too to be powering a 15" sub. I don't think these amps are suited too well for subs, better to leave them for speakers.- Bottom
They use the 2500 because it's BIG power for $300.
Originally posted by ThomasWThey use the 2500 because it's BIG power for $300.
If you only plan on one sub, you could bridge the 1500 and have a bunch of power. I'm possibly going to use my 2500 for two subs, so I wanted more Wpc just in case.Danish- Bottom
