down firing port
  • frazzled
    • 13
    down firing port
    Am I correct in that in a down firing port, you use the diameter of the port to determine how much clearance you need from the floor? A 3" diameter needs 3" of clearance?
  • WillyD
    • 675
    I believe you are correct, but of course the bigger the clearance the better.
    • frazzled
      • 13
      thanks
      Thanks for the help
      • WillyD
        • 675
        I try.
