One of the subs that I need to build will be in clsoe proximity to my PC, and I don't want to risk problems with stray magnetic fields damaging any data on the hard drives. I had originally intended to use the Dayton RF drivers for this room, but overlooked the shielding issue. What drivers are available that are shielded? Sound quality and low distortion are priorities, and the room is about 12x13. Also, listening levels are low to moderate, and I especially would like sensitivity at low volumes.
Also..............
I am building subs for my home and have been comparing amps. The main contenders are the 500 or 1000 watt plate amps from PE, the Bash amps either PE or Oaudio, or prosound rack amps, either Behringer, QSC, or Crown.
Other than the obvious mounting styles to which I am indifferent, what are the advantages of the rack amps over the plate amps, if any. The plate amps seem to have more signal processing capability, while the rack amps seem to have more power for the dollar.
I would like to keep the cost at $200-400 if possible.
Finally, are the digital class amps as good as the class AB amps sonically? I have heard some assert that thee better damping factor of the digital amps better controls the cone movement.
Thanks for any recommendations or suggestions
Also..............
