Guys before I get started here with my request for help with my DIY Sonosub, I would first like to say that I have read all the info that I can find on here but couldn't find anything specific to my application. This is my first DIY attempt so all help is appreciated. I plan on building one or two 12" Sub/s and I would first like your thoughts on the Driver selection, I am considering at this point:
1. Soundsplinter RL-p 12
2. Suggestions
3. Suggestions
I am open to sugestions on other units, I only ask that you keep in mind that I will probably be temperarly powering these with a spare NAD C272 (150 w/chan). Will this amp be capable of driving these subs on a temp. basis or am i wasteing my time to think so? While we are on the Amp topic, if you guys could suggest a more suitable amp I would greatly appriciate it also. Also which coil config should i get 2 or 4 ohm?
Next topic I guess is the actual tube construction, I am capable of building this enclosure but have not actually seen any info on how to connect the end caps in the tube, are they just glued in? if so what type of glue is best?
I have just started using WinISD Pro Alpha and would appreciated if someone could run some numbers for me to compare using a 17hz tune with the SS RL-p12. I seem to find that a 155 cubic litre enclosure seems to work ok but would like to know what some of you more experienced builders might think.
Guys I should also mention that I plan on using this Sub for 80% music and 20% movies in a room about 20' x 17'. I presently have a B&W ASW675 and it goes without saying that I am not satisified with this sub and I want to build something that would totally put the B&W to shame. Also, I did consider buying the Axiom EP-600 or HSU 3HO, will this DIY be comparable to either on of those units and if not what DIY Sub would?
Finally, do anyone know of a free program that I could download to draw sub enclosures, just to expermint with, something that has dimentions would be prefered. Thanks for the patience in reading such al long post.
2. Suggestions
3. Suggestions
