I just wanted a quick sanity check. Since it seems the chances of getting an 18" woofer of quality on the cheap are getting slimmer and slimmer, I'm looking at alternative options to add on to my 2 existing 18" subs (which are in a huge room and don't really get as hard-hitting as I want -- and IB is not an option). I'm inspired by the Genelec HTS6 array, and I keep thinking, "what if I made one of those... but with 15" drivers?"
Would there be any problems setting up an array of 15" subs alongside the 18"s? I was thinking about adding on 4 of the RL-p15's, since it seems that two of them are displacing a little bit more air than the existing 18"s are individually, and they can go in smaller boxes or tubes. I admit I also don't know the effects of the difference in the drivers' resonance frequencies (Fs 24hz for the RL-p15, 16hz for the Ava18 ). Will that cause problems if they're all in ported boxes, say tuned to 16hz?
Of course, any other suggestions are welcome.
