Would a 23.5" x 23.5" x 23.5" outside dimension sealed box be big enough? It would be 1.5" thick all around with one window brace. I will be using a Nady XA 1100 for the amp and for the time being a Pioneer 815K for the crossover. Also what the cutout diameter, mounting depth be? Should I make the front baffle 2.25" thick mounting to the inside out and just cutting out the 2nd and 3rd?
Building a SS 15"D2 First DIY Sub
Sounds good. I'm assuming that you have seen Steve's and mine thread. Your plan is almost exactly the same as ours, but we both built 2. If you haven't seen ours, make sure you check the DIY Sub Showcase thread, and it will provide you the links to probably answer all of your questions. If not, Thomas is here for you.- Bottom
Should I make the front baffle 2.25" thick mounting to the inside out and just cutting out the 2nd and 3rd?- Bottom
Ok, so i was looking at the dimensions on the website and it shows that i should be routering out a circle 15.6", is that correct? Then the cutout will be 13.9-14"? Thanks for the help I have all the pieces cut and am looking forward to putting it together tonight with your help.- Bottom
what size of straight router bit should I use to mount? also would a 1/2" roundover look the best
I use 1/4" solid carbide- Bottom
Which driver would you use ? I'm planning on getting the Dayton 1000w plate amp (512w 8ohm/1024w 4ohm)
My box is similiar 22x24x24 outside dimensions.
Which driver is better in this sealed box ? the 2 ohm or the 4 ohm version ?
Jose- Bottom
I'm planning on getting the Dayton 1000w plate amp (512w 8ohm/1024w 4ohm)- Bottom
Didn't know that...
Any Idea on an high power internal plate amp ?
I need a silent amp, an a plate amp would work better for me than a external pro amp..
I read the manf pdf on partsexpress, it list a Lowpass xover 30-100hz .. But I will be using my pre-processor to bypass the amp's xover..
I don't understand why it would be bad ?
I figured between the parametric eq on the amp and the notch filter on my avm20v2 it should provide some basic eq ..
Jose- Bottom
if you look there, the response of the amp starts rolling off steeply at 20hz, which is bad for the sub because you want to get response below 20hz.- Bottom
Thanks for the help..
What amp would you recomend ? need something silent,
that's why I went w/ the plate amp..
I found the following:
Adire ADA 600 amp (600w@4ohm) $549
O Audio Bash 500w 4ohm amp. $239
Keiga 1000w 4ohm amp $575
Keiga 500w 4ohm amp $350
Is there a 1000w Bash amp ? wtb ?
Which is the best & how much power do I need ?
Jose- Bottom
