Hey everyone I found a place that has every type of fastener on the planet! I know, in the past, I have had to rely on my local big box store for longer screws for thicker baffels. (PRICEY)
Check This Out! www.mcmaster.com
Easy to use: for instance: from the main page scroll down to fastening and sealing, click on socket cap screws, from there you can choose what is most important to you first. weather it be color (black oxidised) or size ( #10/32 ) worth a look!
In no way do I represent mcmaster.com. I just thought it would be an asset to our DIY community.
