There is so much info here it's crazy.
I've been toying with the idea of changing my Tumult sub to a PR setup but honestly I really like it and most likely will end up going with an LT circuit and bigger amp. Anyway, onto my questions.
I've always wanted to build some mains and a center. The woodworking isn't the issue, it's all the info.
For one thing they'll be in my living room so there will be a TV between the L&R. The CC will have to set in font of or below the TV. My current L&R speakers(M&K S-125's) are about 21 inches from the wall(measuered to the front baffle) with about 6" between them and the side of the TV. The TV is pushed back as far as I can so the speakers actually stick in front of the TV about 6". The center sits on the same shelf as the TV and simply sets in front of it. I sit about 7.5' from the CC. The room is 12' x 15' and is open to a small dining area behind the sofa.
I see talk about needing the speakers out in the room, or more room behind them than between them and you etc. Also, the crossover talk is beyond me at this point but it's clear some of the crossovers are designed for the speakers to be setup a certain way in the rooms.
Am I worrying to much? For a first shot at this should I go with something like the NatalieP or the Modula MT? Honestly I really like the looks of the --
Dayton RS WMTW Center & TMWW Mains
or
Dayton RS 3-way towers(not sure what to do for a center here though) and I think I saw something about them costing about 1K each, which is more than I'd like to spend. Also since I've alreeady got a Tumult subwoofer this setup is probably way overkill in our little room.
Thanks for any thoughts,
Brad
or
Brad
