Jon, you said over at Madisound that you had a paper by Baxendall that proves that NFB simply shifts distortion to higher harmonics. Do you have a reference?
The only way I can see this happen is when amps are optimized for maximum LF open loop gain. I don't see how this can happen if the amp is designed for reasonable open loop linearity, and if its open loop gain is moderate and only begins to roll of above the audio band.
Most current designs falls somewhere between those two categories. I can see that they will not be effective in surpressing higher order harmonics, so they shift the relative balance of harmonics (which may be a bad thing), but they do not actually amplify the higher harmoncis.
I have a hunch the whole paper may be an apples and pears kind of argument, and I'd like to see what kinds of circuits he considered comparable.
