I'd like to add a little more bass to my 2-way bookshelf monitors. Instead of just adding a subwoofer (or building a new design), I thought it might be interesting to try using an active woofer as a stand for the monitors. This could be done in at least two ways:
1. Use an active XO between preamp and amps. The problem there is that I currently run an integrated amp.
2. Use speaker-level inputs (is that high-level or low-level?) on a plate-style amp on each woofer.
I don't need earth-shaking levels of bass - just enough to feel the music a little more. My system is used for 60% classical, 20% rock, and 20% 2-channel home theater. A pair of 10" woofers would probably do the trick.
Anyone have any experience with something like this? Any major concerns with the basic plan? I've seen the BESL subwoofer stands, and I guess what I want to do is somewhat similar, though I don't think the BESL option includes amplification.
