Hello everyone-
This is my first DIY speaker and I have been playing around with the crossover for a little while. Here is what I have so far. I would appreciate any advice and criticism.
Crossover schematic:
Component values:
3-Way Crossover Network
Low-Pass (LP) Filter: 1 required
Type: 3rd-Order All-Pass (APC)
Desired Corner Frequency: 500 Hz
Band-Pass (BP) Filter: 1 required
Desired Lower Corner Freq: 700 Hz
Desired Upper Corner Freq: 4000 Hz
High-Pass (HP) Filter: 1 required
Desired Corner Frequency: 3400 Hz
C1 = 7.524 µF, Polypropylene, 0.00589 ohms
C2 = 18.45 µF, Polypropylene, 0.00383 ohms
C3 = 32.03 µF, Polypropylene, 0.00294 ohms
C4 = 102.1 µF, Polypropylene, 0.0015 ohms
C5 = 10.1 µF, Polypropylene, 0.00508 ohms
C6 = 209 µF, Polypropylene, 0.00132 ohms
L1 = 0.161 mH, Air Core(#16), 0.268 ohms
L2 = 0.844 mH, Air Core(#16), 0.347 ohms
L3 = 0.43 mH, Air Core(#16), 0.299 ohms
L4 = 0.099 mH, Air Core(#16), 0.261 ohms
L5 = 0.879 mH, Air Core(#16), 0.351 ohms
L6 = 0.359 mH, Air Core(#16), 0.291 ohms
R1 = 0.645 ohms
Woofer
L-Pad: 1.00 dB
Rp1 = 0.222 ohms
Rp2 = 5.581 ohms
Response graph:
Component values:
R1 = 0.645 ohms
Woofer
L-Pad: 1.00 dB
Rp1 = 0.222 ohms
Rp2 = 5.581 ohms
Response graph:
