I just perused the Audiogon listings and many speakers can be had for about 1/3 of their original retail price. Obviously there is a certain risk factor with buying used, but setting that aside as well as the "cost" of your own labor and other intangibles when doing DIY , how do the two compare (let's assume the speakers have comparable design characteristics)?
As an example, here's a description of a commercial speaker that I like that sold for about $3k/pair new and is now offered used at $1k:
"Wonderful curly maple 2 1/2-way designed full-range speaker that has extemely good bass for only 6.5 inch woofers. 25Hz-20kHz frequency response @ 8 Ohms with 90 dB sensitivity. Two 6.5 poly-fiber cone woofers with diecast magnesium basket. 1.125 inch silk dome tweeter in its own double chamber dampened with SoundCoat. Phase: ±30 degrees, 20Hz–20kHz, Xover (2nd order): 2.7kHz 12db per octave Robust design, they are only 9W x 44H x 13D yet weigh 100# each. Four 24-carat gold high quality bindging posts. Internal wiring Analysis Plus."
What's a good ballpark figure for parts to match/exceed these in sound quality? Ditto for number of hours to build (beginner level, some woodworking skills and good set of power tools)?
Frank
Frank
