I'm building a component rack where on the on the top level I have my projector, so it will technically be a hushbox. It is open on front and back on the bottom parts, then on the top I have all 6 sides covered. Does abyone know where I can get some small, low voltage, quiet fans? I've seen the ones at parts express. Are they quiet? Also, I need one big fan(or would it be better to get a small one for noise control) for the projector fan's hot air. Any ideas?
building component rack and need help
For quiet fans, look to some 120mm Nexus fans designed to run on 5-12V. Their classic colors are orange and I think they now have black frame with white blades. Run ~10-15, don't remember exactly.
Consider leaving the top open, at least partially.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
Originally posted by cjdFor quiet fans, look to some 120mm Nexus fans designed to run on 5-12V. Their classic colors are orange and I think they now have black frame with white blades. Run ~10-15, don't remember exactly.
C- Bottom
Well, most projectors shed a great deal of heat off the top, though not all. I was making an assumption when I suggested no top that may not be so useful after I poked around looking at some projectors. You're going to need to take care to supplement and maintain the natural airflow of the projector by adding hushbox airflow so it doesn't try to make it go the other way or something.
As long as you have enough space around the projector and adequate airflow in the correct direction... it's a tricky game regardless. Just take care with it.
