hello...new poster here. I'm wondering about the distortion characteristics of two drivers with different values of Fs. This assuming that each sealed f3 is the same...say 20 Hz, for example. I have modeled a Tumult 15d2 vs. (2) 12inch tc7 drivers from tc sounds...the tumult's fs=16 Hz and the tc7's fs=23 Hz.
I'm wondering how they would perform against each other at the lower frequency (16 Hz). I'm having a hard time believing that these two systems would sound the same with the same L/T equalization curve.
It seems that there must be some apparent advantage to using the bigger driver. In the tumult's case, with a massive 33 xmax and Pe of 1kW, it models about 1dB higher (spl) against the dual tc7's. I'm wondering if it would also be cleaner below 20 Hz than the dual-tc7's.
I'm starting to think that maybe something is amiss in winisd pro. :roll: Thanks
