Hey I'm new to here and DIY in general. I currently have a Panasonic HTIB with a sub that only goes down to 45hz, and it leaves me longing for something better. Well I'm selling that set to a friend and have upgraded the speakers to the Athena Point 5s and the Onkyo TX-SR503, which should be here next week. I don't want to shell out a lot of money for a good sub, so I've decided to go DIY. I think I've secured a deal on the 250w sub amp from Parts Express for $80 and maybe the 15" Dayton DVC for the same price. I don't really have the biggest space to put this woofer (about 22x25x25in), so I may have to go sealed. What kind of extension can I get sealed? I want something that's musical and accurate, not boomy, but I also want something that will have that visceral punch for movies. Any suggestions? Thanks!
Dayton DVC DIY?
Tags: None
You can model the anechoic response using any of the computer based subwoofer design programs.
Boomy is usually more a function of the room/room placement than it is a characteristic of the driver.
The DVC 15" is a virtual drop-in replacement for the Adire Tempest in any of Adires recommended enclosures.
You can find the Adire Tempest apps in the link below
I'm thinking of a 23" cube with 1.5" mdf sides, which would give it a 4.63ft^3 internal volume. Would this be sufficent for good extension to 20hz?- Bottom
