I'm currently (seemingly perpetually) in the design phases of a 3 way. For domestic tranquility, the speaker should be fairly slim (~8").
I was originally hoping to use a Dayton 10" HiFi sub in a side firing configuration, with a peerless 850439 as the mid. Unfortunately, the HiFi won't go low enough sealed and a vented box is too big. I don't want to deal with an LT type active EQ circuit.
So, I'm thinking about 2 extremis per side, crossed over at 250-300Hz to either a peerless 850488 or the seas MCA15. This models really well, but I have concerns about the quality of the extremis' bass. Their distortion numbers seem to be only average and 300 Hz is an important area musically - lots of fundamentals in this range.
I've read a lot of complaints about the extremis' distortion numbers at higher frequencies, but for bass duty it's harder to find opinions.
I'm really trying to pick low distortion drivers for this design and use them in their appropriate ranges. Does the extremis fit the bill? Are there better options?
Thanks in advance.
Thanks in advance.
