Like most of my projects I seem to take way too much time trying to find the proper hardware or a method of doing something wacky, so the time spent isn’t really indicative of the difficulty, just a product of my finicky attitude and desire to do things that no one else would do.
The fit and clearances along with the proper hardware for the gimble assy was probably the hardest part of the project, although I have an even deeper appreciation of the difficulty in aligning grains and matching different pieces of wood together to give a homogenous look. Working with hard and soft woods mixed is another challenge that I find very frustrating at times. The full adjustment range exceeds 6 inches at the rear articulating ball assy, which on second thought was probably the single most difficult to devise and construct. The adjustment can aloe close to 30° of angle on the mid/woofer cabinets relative to the tweeter pod. Every part can be removed and broken down like a gun, each mid enclosure pivots on a spring loaded pin that fits into a receptacle and can be depressed for removing the enclosure from the gimble mounting ring. Everything is solid Oak or painted MDF to match my mains. The tweeter pod is easily removable with the ¼ -20 bolt behind the faceplate.
The prototype has been up and running for months so I have tweaked the sound to very satisfying results already, these little woofers will pack a whallop for their cone area, but a little overprices IMO.
Woofers- Scan-Speak 8530-K01S
Tweeter- Vifa XT-25 with custom faceplate.
Crossover- Marchand XM44-4 (2.6K 4th order)
Woofers are paralleled (2-way) and powered by the Halo A-52 and a separate channel to the Tweeter.
Pictures
Pictures
