I have been messing with LspCad and the new KHF tool. As I'm planning a new high quality, higher cost speaker project I want to do better than my FatMargaret project from few years ago.
Back then I assumed that if I round the edges so much then it will not leave me too many diffraction problems - I was wrong....
Why you ask - did it measure that bad. Well yes, it seems it can be done much better.
I started by creating a response of "ideal tweeter" and used the new KHF Tool for study
Then I simulated the tweeter as it is in my Fat Margaret.
Now the comparison of the simulated response againt the real measured response of the tweeter in above box
brownish = simulated
grey = measured 60cm on tweeter axis with 6ms window.
So it can be pretty much said that the rounded edges do not make too much difference
Now I know better for my next project
To be continued....
Ergo.
To be continued....
Ergo.
