Hey all... I recently finished my Exodus 261s, and just now was able to snap off some pics with a borrowed digicam. I had to work on these on my deck during the summer, as I have no workshop. Limited tools also prolonged the build process. The finish took a long time even though it is still FAR from perfect, as I don't have an air gun. I used spray paint instead.
Ewww black is bad for finger prints and dust... perhaps I should clean them before taking pics next time.
In the wide shot you can see the projector I am making. That's not the final position, just the "work in progress" place. I actually might re-make the entire enclosure though.
Here's the tempest I posted a while back. The stand is now painted and the front plate on the crossover/volume control is fixed.
Please excuse the mess, as the room is being used as my lab, so there are tools/junk all over.
Overall I am very pleased with the setup! I have a long way to go, as you can see. Still need an LCR and 2x61s, for surrounds. The walls are bare, and the floor is a rug over concrete, so wall treatments are the next thing on the list. The speakers are at the far wall of a 12"x24"x8" room... Any suggestions regarding possible better placement?
Thanks for looking! Tell me what you think.
