How many of you guys use sealed sub designs? What works for you? Lets see some pics!
Sealed subwoofer guys
*raises hand*
3000 cubic feet in the box. Two fifteens. 240W. Love it, though the drivers leave a bit to be desired - just waaaay too much mechanical noise down low.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
I used a dual Tempest .6Q wall mounted sub for years and loved it.
Contrabass ported? I thought that the contra had dual active and dual passive radiators.
Subs for the mains too, cool.
Ajpoe,
Just wondering how many filter banks do you use on your BFD.Once I figured out TrueRta I got it down to two banks.Do you use any electronics to extend the frequency response?Here is my LCR "Trio". Way to go guys !- Bottom
Originally posted by sfoggpassive radiators are just another type of port.
Their own sets of benefits and downfalls. Response is often equivalent to what you could achieve using a port. But ports, they are not.
PR's and ports are both 'vented' alignments, let's just leave it at that.... :wink:
Originally posted by ThomasWAnd you traded it in for a _____ ? :wink:
Actually, I think the Tempests sounded better at low volume than the AV12s. Must be the suspension. I actually thought about trying 4 DPL12s instead but not sure if I want to give up the overhead. Of course I've put off some tests with the AV12s to make sure it's not related to something else.
Pete- Bottom
Now Tom, that's just not fair.
IIRC you used some sort of velvety fabric right? I'm rethinking some of my finishing options of my sonosub and I think this might look good. Also, where did you get it and approximately how much was it?- Bottom
Might as well post my specs too even though it's not fully completed yet.
15" Avalanche ~100L (~3.5 cu ft.) with a Q ~.547 powered currently by the ~100 watt amp off of my 10" dayton sub until I can figure out what's wrong with my EP1500. The thing still pounds off of 100 watts which is probably why I haven't gotten around to actually figuring out exactly what's wrong with my pro amp.
Images not available- Bottom
Originally posted by kgveteranAjpoe,
Just wondering how many filter banks do you use on your BFD.Once I figured out TrueRta I got it down to two banks.Do you use any electronics to extend the frequency response?AJPoe - - Growing old is inevitable, growing up is optional!- Bottom
Here's my lastest shiva sub, a 62l sealed powered by a 360w plate amp. Sold my last 95l vented, as my wife told me it was too big. So I built two like the one posted and she only "allowed" me to keep one in the room, the other is awaiting a buyer! I was planning on using each one a speaker stand for my new Audax mains I also built at the same time. Next time I will build abigger room! :W
Image not available- Bottom
