I bought some sony headphones today. the ex71's suggested on Linkwitz's site. they are pretty clear. although I keep hearing a shhh, zhhh, pshhh from the chraracters in my movies. high pitch noises also sound piercing. anyone have an ideal what it might be.
I hear Zzzzhhhh, Pshhhhh in my headphones
If you are playing the dvd off your computer the first thing I would say is that it's the internal noise of the computer itself. This is especially bad with onboard sound cards. It can be so bad that you will get sounds even when using the scroll feature on your mouse!
But as jdybnis said, we really need to know the components you are using.
EDIT: oops I was too late! what sound card are you running?- Bottom
Never used it, but it fits the bill.-Josh- Bottom
getting a good sound card will greatly help your situation, and eliminate almost all computer induced noise. As for headphone amps I can't really recommend any as mine run decently off of phantom power (if thats the proper definition ) from the front bay on my system- Bottom
Shame on you....the AudioWorx
Just ask Mr. Ohm....- Bottom
Integrated audio on Intel boards is notorious for being absolutely completely uselessly noisy.
Aftermarket chipsets are quite often better, if not very good (but I have yet to find one that's up to doing speaker measurements... S/N is still only mid 80's on any I've tested)
For quality sound, look to an M-Audio board. Rev 5.1 is a good deal at ~$75.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
The new soundblaster X-fi music
The new soundblaster X-fi music kicks butts much better than m-audio
The Sound Blaster product range has an audio upgrade solution – internal and external—for every setup. Don’t stop at stunning visuals. Redefine your audio experience with Sound Blaster.
I have it connected in digital out on my rotel and sound better than my denon 3910.
but I do agree that its better external cards
have fun- Bottom
after reading the linkwitz site some more, I see that the headphones have a peak in response at 5.2k and perhaps above. I download an EQ online. not sure if it works as well as an convential active or passive type. but I think the sound has improved. this peak was likely the piercing I heard. but not the hiss in the voices.http://joy2meu.com/- Bottom
