To cut cost and look for a more interesting enclosure I priced some 8" PVC tubing (the thick green stuff ) for enclosure purposes.Has anyone used this material before ? My thoughts are to use the 8" stuff for the woofers (6.5" drivers),6" for the midrange(5"mid) and the 4" for the tweeter (just for looks).
The enclosure for the 6.5" drivers will be sealed and small because they will be handling only 80hz and above.I'm sure they will be at least .5 cu. ft. ( or slightly larger if needed )each.The midrange will need an even smaller enclosure.
The xover will be external in the base.Whatcha think?
