Since I had such great success with my DIY sonosub, largely in part because of all the great help I received on the audio forums, I am now interested in building some DIY mains and a center. I realize building a successful speaker will be a lot tougher than a sonosub, but I am in no immediate hurry and will do as much reading and researching as I have to. I was pretty set on auditioning some Ascend 340s, but I am wondering if I can get the same performance out of DIY speakers that I did out of my sub if I use a similar "no compromise" approach. I plan on these speakers being as large or as extreme in design as they need to be. No WAF or much of aesthetic concerns for me - purely performance.
The design I have in mind is a MTMWW similar to the one Brian has going. The main design difference is that I plan on isolating each driver in its own sonotube enclosure. The tubes will be mounted in an MDF shell that will consist only of an exterior and some braces inside to support the tubes. This cabinet will probably be very deep in order to supply enough length to the tubes for the woofers to come out with a pretty optimized volume. Without yet knowing much about how to build speakers, I assume this design would instantly eliminate several of the common problems associated with cabinets, volume, and driver interaction.
I am pretty set on using the Vifa Ring tweeter, as I have heard nothing but good thinsg about it. For the rest of the drivers, I am not so sure. Since my sub can handle everything below 100hz with power and precision, I don't need deep extension. Based on the limited researching I have done so far, I am thinking of using a pair of Hi-Vi F5 midranges and a pair of Dayton RS270s. I believe in Brian's thread, cjd suggested the Dayton Reference Subwoofer drivers might have been a better choice.
Also, since I am trying to go strictly for performance, is MTMWW not a good option? Would an open baffle or something else be much better?
For a crossover, since I only have very limited circuit knowledge/experience, active crossovers might be a very real choice.
Basically, I was hoping you guys could point me in the right direction to start learning about driver layouts, baffles, impedances, crossovers, etc., all the basics I would need to know to start building a set of speakers. I'd rather not buy a book because I'm sure all of this info can be found online, but if I had to, I would. Also, what programs can I use to start playing around with deisgn parameters and get predicted results?
I would appreciate any and all help. If I were to optimize this design as much as possible, I am assuming a speaker based off of the Vifa Ring tweeter and some high quality woofers could outperform the 340s? I ask because this project will likely cost me around $1200, about twice the price of the 340s.
