I have a Proxima 5900 with a burned blue polarizer. I bought a similar projector so I could take its polarizer and replace the burned one with it. Can someone tell me where these polarizers are and what do they look like?
replacing blue polarizer
You really need to buy a service manual.
Only then will you understand what a monsterous undertaking this operations is....... 8O
I have taken this projector apart and put it back together again a couple of times, but I have not seen any glass that looks burned in any way. If you can give me a clue as to what a blue polarizer looks like it would help. If I ruin the projector it does not matter. Since it did not work right it was free.
thanks- Bottom
Thanks for the link and Info, Dennis. Polarizer plate replacement and adjustment isn't a casual task. Bill Cushman discussed the process a bit for the 400Q once with me years ago, and some ways to tweak it and get the contrast ratio up a bit further. As Thomas recommends, having a service mnaual is a VERY good idea. I bought one for the 400Q I used to have (it's been with ThomasW quite a few years).
~Jonthe AudioWorx
Just ask Mr. Ohm....- Bottom
