Ok, now that the subs are done, I'd like to maybe add a switched outlet. The BFD and K1 have to stay on all the time or I have to manually switch them off/on. I'd like to get something simple that will sequentially turn on the K1 and then the BFD (to avoid the pop) when I turn on my processor but I don't want to spend a ton either. Is this something that can be built? I also have a DAC1 which I have to keep on at all times. If I could have it turn on only when my 1068 turns on too, that would be great.
If it isn't something that easy/cheap to build, then I guess something like this would work?
