Ported ava 15" for HT Help
  • BlakeN
    • 22
    I did a search for avalanche and read all the threads that came up but none had my answer. If I overlooked something feel free to post links and say "look here dummy" :T
    Now, on to the good stuff. I have an ava 15" and I want to build a 100% ht sub. Size is not an issue. Room dimensions are 13"x20"x8" closed door. I have thrown around all sorts of Ideas in modeling software but to be honest I am still completely undecided.
    Here are the sizes and tunings I have on the top of my list.
    7^3ft @ 16Hz
    10^3ft @ 16Hz
    5^3ft @ 20Hz
    and at one time I was even considering 14^ft @ 12Hz
    Low is more important than lowed to me. I have a wife and a live in a townhouse.
    Please someone help me!
    Unless you enjoy lugging around a 500+lb box you might want to consider something a bit smaller. The design in the link below has been copied numerous times with good success
    AS-15
    • BlakeN
      • 22
      I was going to go with a sonotube design to cut down on the weight. I will be ordering a 6" flared port from my local dealer even though it will run about $60 (ouch) for the ends.
      • Bent
        • Sep 2003
        • 1570
        Good luck on finding the flare(s) - apparently there are still some around...
        But my contact has sold all of his, and I'm getting the urge to build again. :T
          Here's a tube version of the AS-15 I built for my friend Pete
          Ben,
          Word is that any lightning audio dealer can order the flares, have them use part number PNR6BK-PT
          • BlakeN
            • 22
            I actually contacted lightning audio to make sure they were in production, which they are. Then contacted my local dealer. Of course he said he couldn't get anything like a 6" flare. So I asked him if his store was an authorized lightning audio dealer. He said they were so I gave him the part number and after about 3 minutes of looking through his book he finally found them. This was about 2 months ago.
            Tom, I have looked at that design on several occasions. My question is what do you think the optimal internal volume and tuning frequency is for this particular speaker. I modeled the bp 1503 in that box to get an idea of what it is theoretically doing in that setup. The ava 15 performs quite a bit differently. After some experimenting it looks like an ava 15 in 9^3 @ 16hz performs about the same as the bp 1503 in that setup.
