I have gathering dust at my house an APC Matrix-UPS 5000, a 4.7kVA UPS that puts out very clean sine wave AC in normal operation. (When inverting from batteries to AC, the wave form is nothing to write home about: okay for computers but not what you would want to use for audio.)
This UPS has a cut core transformer inside that must weigh close to 130 lbs. It is designed for 200/208/240V input, and it can output those voltages as well as 100/120V.
Since I have no use for the UPS (my house in Tokyo is not wired for 200V), I have been toying with the idea of removing this monster trannie from the UPS and using it as an isolation transformer. In my case, that would mean I would be inputting 100V to the primary side rather than the 200V that the transformer was originally designed to work with.
My thinking is, if you can get out 200VAC from the secondary side by applying 200VAC to the primary side, those same windings should yield 100VAC when 100VAC is input.
Is that line of thinking correct? Or am I missing something? As a newbie I am reconciled to the fact that many of my imaginings are just that, vain imaginings. I see lots of transformers listed as 240/240, and others as 120/120, and of course some 240/120, but I don't think I have ever seen a transformer where the manufacturer claimed that the same sets of windings would be equally suitable for either 240/240 OR 120/120 applications. Yet it seems to my "newbie mind" that a 240/240 transformer should also work as a 120/120 transformer simply by halving the input . . .
Any insights in this dept. would be greatly appreciated!
Christopher Witmer
Tokyo
Christopher Witmer
Tokyo
