Andrew recommended I post here, so here it is
For background of my home theater progress...
I currently have a SVS PB10-ISD I'm trying out. Potential budget for this project if I return the SVS will be around $800, $1000 Max.
I live in an apartment, so 15A is the one and only power option. I'm a single guy, so dimensions can be like 3'x3'x8' with no WAF to worry about.
I'm experienced with mechanics and the use of most tools, but my last wood project was in 8th grade. I can weld if this gets serious... :rofl:
I want solid inaudible infrasonic response that I can feel mixing my spleen and small intestines around when listening to pipe organs on SACD. I have five bookshelf monitors and due to my pre/pro the crossover during analog bypass is 80Hz, so this thing will need to blend well with them. I am pretty picky about the bass getting at all congested or even warm, so I'm looking for lightning fast response and good decay. My room is roughly 1500ft^3. Here is a layout (sometimes the link won't work, but if you click it 3 or 4 times it will).
I know this is alot to ask for the money, but I'm hoping someone has a solution. For HT I normally listen at the 75dB calibration point, but need something that can issue that quick slam such as when Saurons finger hits the ground in LOTR: FOTR, or give a very clean response of Frodos heartbeat in LOTR: ROTK. Response in scenes such as the Pod Race in SW: E1 needs to be clean and deep without rumble.
Ok, I think thats the jist of it...
